05 Honda crv - rear turn signal issues
Hi all, new here. I have an 05 that has a rear turn signal that won’t work. Symptoms are fast blinker on passenger side. I replaced bulbs, still dosnt work, swapped bulb with drivers side, and both bulbs work on drivers, dosnt work on passengers side. I used a multimeter and I get 3 volts? On passenger side, and then a little more. I am not good with electrical on cars. Does it sound like a bad harness or socket? Anything else I should check? It is the UK version VS Japan. This car has 235k on it, and lives in Wisconsin. Thanks for any input, ect…
Thanks for the input. Yes, salt, brine and who knows what else. Are there a number of grounds on these? I also get other phantom electrical issues at times.
Phantom issues could be a ground that is loose.
22A-30 or -31 may be where you need to check.
The grounds are in the circles.
Here is the index;
Here is the index;
Last edited by tech8; Dec 30, 2023 at 06:41 PM. Reason: Links to copyrighted material deleted.
rkrone
14
Aug 26, 2006 06:38 AM
Fuster_Cluck
Honda Motorcycles
Jan 30, 2004 06:08 PM
