Motor mounts don’t fit right
Old Oct 22, 2023 | 09:56 PM
Damian415's Avatar
Default Motor mounts don’t fit right
Have a b swapped eg that came with hasport mounts. The poly bushings in them looked crusty so I decided to purchase replacement hasport bushings. Took old ones out slid new ones in. Mocked them up in the car and noticed that they slid in with no resistance and after torquing down to spec the poly bushing face to chassis bracket had about 1/4 inch of gap between them. Seems like installing the motor like this would allow the motor to move back and forth. Could I bend the motor mount brackets to eliminate the gap or should I return the bushings for thicker ones???
Old Oct 23, 2023 | 07:28 AM
Hasport's Avatar
Default Re: Motor mounts don’t fit right
the urethane does not need to touch the sides of the pocket the mount sits in. if it did there would be much more vibration transferred to the cabin. the pin in the middle keeps the mount in place
Old Oct 23, 2023 | 10:40 AM
Chance EG's Avatar
What Hasport said. I have 1320 mounts which are knock-offs of the Hasport design, and they sit the same way.
The rubber is to insulate and reduce vibration from the center sleeve, you don't want the rubber touching the metal mount point.
Old Oct 23, 2023 | 02:25 PM
Damian415's Avatar
really cool that there’s a hasport rep on the platform. Thanks both of you guys for the explanation and setting my concerns to rest.
Old Oct 24, 2023 | 07:37 AM
Hasport's Avatar
you need to get those gone and get a set of Hasport mounts in there
Old Oct 24, 2023 | 09:26 AM
Chance EG's Avatar
First things first get the car finally moving... Too many 0 mileage parts that have been sitting in there for months :/
"Soon", he said for the 20th time over the last year.
madmantrapper
Honda Civic (2006 - 2015)
Apr 8, 2014 09:41 AM
89LSED
22
Oct 4, 2010 04:50 PM
bbabyboy715
Sep 17, 2008 10:33 PM
civic_driver
Nov 1, 2005 10:22 AM
eg686
29
Apr 7, 2005 09:19 PM
