Honda CR-V & Element 2WD & 4WD Element & CR-V
2002 Power Steering Pump Outlet Differences
Old Oct 17, 2023 | 11:05 AM
scoostraw's Avatar
Default 2002 Power Steering Pump Outlet Differences
I am replacing the power steering pump on my 2002 due to a very loud bearing noise. When I went to do so however, I discovered that the outlet on the pump where the return hose connects is in a completely different place than on the original.
I actually have 2 replacement pumps (long story) - both are OEM and both differ from what is on the engine presently. I am not the original owner of this car, so I can't say for sure that what is on there now is factory original.
I'm fairly certain the return hose has enough reach to connect to the replacement pump. This really puzzles me, as the return is on the complete other half of the pump. It's not a simple case of an outlet facing a different direction or something.
Have any of you guys run into this?
Old Nov 2, 2023 | 11:31 PM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
Default Re: 2002 Power Steering Pump Outlet Differences
Yes, I ran into this exact issue with a power steering pump from RockAuto.
I rerouted the line more towards the front of the vehicle. I can take a picture in the daylight if necessary.
Old Nov 4, 2023 | 03:57 AM
scoostraw's Avatar
Hey Smackin thanks for the reply.
I was going to do the same thing - reroute the hose. But in one direction is was too close to the belt pulley. And in the other direction it tended to collapse upon itself.
The pump I got is from another car. (I preferred to rebuild an OEM pump rather than roll the dice with an aftermarket pump) So I went back to the junkyard where I got this pump and grabbed the correct return hose. Problem solved - for my case anyway.
Thanks again.
dk127
Jun 20, 2021 10:52 AM
smcdonaldaz
Acura TSX
Dec 10, 2019 01:21 PM
moh.rwashdeh@ya
Apr 12, 2018 04:37 PM
Aslan14
13
Mar 21, 2008 08:08 PM
RACEPAK
Nov 20, 2006 08:08 AM
