Honda CR-V & Element 2WD & 4WD Element & CR-V
CRV 2007 overheats
Old Oct 15, 2023 | 08:29 AM
Naco_1976's Avatar
Default CRV 2007 overheats
Greetings to all,
I have a problem with a 2007 CRV, it overheats and everything is already done.
1 the electric fans replaced
2 the radiator was replaced
3 the cylinder head was changed
4) 3 cylinder head gaskets have been changed
5 the ETC sensor was replaced
6 the water pump was replaced
7 the thermostat was replaced
It is still overheating, after it reaches 95 oC (203 F) the temperature does not drop any further.
I really don't know what to do anymore
Old Oct 19, 2023 | 06:36 AM
kmf's Avatar
kmf
Default Re: CRV 2007 overheats
207 degrees is not over heating. Relax. Do a browser search on temp range of auto engine, typically 195-220
Old Oct 19, 2023 | 05:30 PM
chidog's Avatar
What is saying its too hot? A warning light? The gauge? I'm not sure is there a separate sensor for the gauge? The engine coolant temperature sensor is for the electronic engine control. Yes its easy to also use that for gauge reading but not sure if they do.
And yes 203 F is not all that hot, for modern day stuff, the 180 F days are gone, higher temps now for emissions related stuff.
Travers
Apr 12, 2017 09:50 AM
092eg6
13
Jul 19, 2010 11:26 AM
hondamike89
Feb 28, 2009 01:40 PM
aziaticvang
18
Jan 29, 2008 02:16 PM
91civicEX
Oct 17, 2003 04:00 PM
