Brake light stays on while I drive, even tho the Ebrake handle is down... what gives?
Old Nov 18, 2002 | 02:06 PM
94GSRRacer2's Avatar
New User
Default Brake light stays on while I drive, even tho the Ebrake handle is down... what gives?
When start my car up in the mornign, my brake light stays on, even though I have the ebrake handle down. sometimes it goes away, but if i step on the breaks hard, it comes back on, until i let go, then it goes off again. sometimes it stays on the whole day. it has done this ever since I bought the car. It's a 98 SH by the way. any suggestions?
Thanks for your help
Old Nov 18, 2002 | 02:08 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Brake light stays on while I drive, even tho the Ebrake handle is down... what gives? (94GSRRace
my BMW does that, and i have no clue why
Old Nov 18, 2002 | 02:15 PM
4bidden's Avatar
One of the filaments in either of your taillights is out. Have someone step on the brakes while you watch from behind.
Old Nov 18, 2002 | 02:31 PM
New User
I meant the brake light on my instrument cluster. all my lights are working fine, just the light that comes on in the dash when you pull the ebrake handle stays lit.
Old Nov 18, 2002 | 02:38 PM
New User
Old Nov 18, 2002 | 03:29 PM
jc836's Avatar
Appears that you may have a bad switch under the e-brake assembly.
Old Nov 18, 2002 | 03:41 PM
4bidden's Avatar
Are you positive you dont have a partial taillight out? One of them when you hit the brakes might not be lighting up with the other filament. Double check.
Old Nov 18, 2002 | 05:32 PM
laughinxxx's Avatar
New User
There is a very simple sensor under the E brake lever. Pull the armrest off and make sure that it is tight. One bolt came loose, which changed the position of the sensor and triggered my E brake light.
Old Nov 18, 2002 | 05:37 PM
wildstallion's Avatar
check your master cylinder and slave cylinder fluids.
Old Nov 18, 2002 | 08:15 PM
ryanstev's Avatar
What has the slave cylinder got to do with brakes?
Old Nov 18, 2002 | 08:39 PM
DsITR's Avatar
he said master cylinder, as in master BRAKE cylinder..
Old Nov 18, 2002 | 09:14 PM
ryanstev's Avatar
The master cylinder is for brakes, slave cylinder for the clutch.
Old Nov 18, 2002 | 09:26 PM
ChargedLude97's Avatar
Mine does the same thing sometimes when it's cold outside.....don't know why
Old Nov 18, 2002 | 10:46 PM
SuperSH's Avatar
Pull the master cylinder cap off and tap the cap a little then put it back in. Make sure that the brake fluid is at the correct level. The float likes to stick. If that dosent work then check the adjustment on the e-brake cables and tighten the 10mm adjustment bolt behind the e-brake if there loose. If the handle dosent go all the way down or is loose then tightne the cable adj. nut.
Old Nov 19, 2002 | 12:07 PM
Too_Funny's Avatar
I used to own an Accord that had the same problem. I later found out my brake fluid was just a little under low. Filled it back up to high and everything was okay.
Old Nov 19, 2002 | 03:18 PM
New User
hey guys thanks for the tips. just checked the brake fluid, it's about 1/2 an inch above the min line, and 1/2" below max. I'll add some more fluid. Thanks for the help
Old Jun 30, 2004 | 02:38 AM
calvinkw1's Avatar
sorry to bump up an old topic but as i'm a complete newb i have no idea where or what the master cylinder looks like.. and i also have no clue how to get to the bolt to tighten the ebrake line.. if anyone could help me it would be greatly appreciated.. i already did a search and came up with this old thread.. so yeah..
Old Jun 30, 2004 | 02:42 AM
calvinkw1's Avatar
Old Jun 30, 2004 | 10:02 AM
SKDRCR's Avatar
Here is a pic of it. top off the fluid even if it looks good
Old Jun 30, 2004 | 11:33 AM
calvinkw1's Avatar
thanks.. i don't know where it's located but i'll see if i can find it
Old Jun 30, 2004 | 02:03 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift_lude &raquo;</TD></TR><TR><TD CLASS="quote">thanks.. i don't know where it's located but i'll see if i can find it</TD></TR></TABLE>
Look to the left of the brake booster if your staring at the engine
on the drivers side.
Old Jul 2, 2004 | 10:21 PM
letmeseeyouskip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
on the drivers side.</TD></TR></TABLE>
YEAH its your brake fluid its low and you probably need new pads
Old Jul 3, 2004 | 03:34 AM
calvinkw1's Avatar
nah brake fluid is fine.. front pads were recently replaced this year.. project mu.. they've gone through 2 track days and are perfectly fine.. but the rear i need to replace.. i have pads and rotors sittin in the garage.. u really think the rear pads are the problem?
Old Jul 3, 2004 | 03:06 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift_lude &raquo;</TD></TR><TR><TD CLASS="quote">nah brake fluid is fine..</TD></TR></TABLE>
When you say it's fine, do you mean there is some in there,
or do you mean it's completely full and topped off with fluid?
Old Jul 3, 2004 | 03:22 PM
calvinkw1's Avatar
it's right in the middle.. friend had a look at it and said that's where the fluid level should be.. is it sposed to be topped off?
tpot90
Nov 19, 2007 08:26 PM
outlawstar27
May 18, 2007 09:04 AM
DaCRXboi
Mar 17, 2007 10:17 AM
DSMRacing
Mar 29, 2006 10:37 AM
FalconMan
Jan 28, 2003 09:21 PM
