Dying after warm up
Old Oct 4, 2023 | 09:55 AM
ChrisE5's Avatar
Default Dying after warm up
In this last year we picked up a 93 coupe EX, Y8 swap, and it's been really solid so far, threw my old wheels on and quickly fabbed heat shield I built for the plastic hot air intake that it came with however we came across an issue after my father used it for work, i went to leave and after warm up it slowly died, we tried two different spare ignition coils, changed ECT, and tried 2 spare icms i had in my stash(toolbox) with no change. Fuel pump priming again after dying tells me it's not ECU, and I hear the main relay so I think it's another part in the dizzy (ignitor, tdc, etc), but before I jump the gun and buy a new one (if i cant find one at the junkyard friday) does anyone have any helpful insight to point me in the right direction? Thank you in advance.
Old Oct 6, 2023 | 07:18 AM
ChrisE5's Avatar
Default Re: Dying after warm up
Also can I run a Y7 dizzy for now ? I have one lying around from my old 00 sedan
Old Jul 30, 2024 | 07:10 AM
ChrisE5's Avatar
Update I think I have discovered my issue, according to this post I should have bought a dizzy from a 92-95 and used those internals in my old Y7/Y8 dizzy housing, as I am using the obd1 ecu that came with it, simply using an obd2 dizzy would not work, but any advice is still much appreciated
Edit: Dizzy is installed with obd1 internals and still nothing but I finally got the CEL that we had before it died to return and checked it, it's a IACV code but I'm unsure if that would cause it to not spark
buffarlos
Sep 9, 2020 12:16 PM
Mark Ross
May 30, 2016 06:45 PM
boosted_fuzzy
Engine Management and Tuning
May 28, 2013 06:06 AM
bnoland
Jun 29, 2012 09:43 AM
piratesvarsity2
Feb 13, 2010 10:31 AM
