2nd Gear Grind
Old Sep 26, 2023 | 08:36 PM
HahaPrelude's Avatar
Default 2nd Gear Grind
I have a 2001 Manual prelude and it recently started grinding when shifting into 2nd at redline. It's only happened three times. Is there a way I can fix the problem before it gets too bad or is it already too far gone and I need to do a rebuild on the tranny?
Old Sep 27, 2023 | 08:19 AM
Aradin's Avatar
Premium Member
Default Re: 2nd Gear Grind
Try replacing the fluid with Synchromesh or equivalent. Otherwise, once they start grinding the damage is already done and it will only get worse going forward.
jordan_rael_420
Feb 26, 2009 05:05 AM
creepy116
Dec 11, 2006 12:21 PM
tcontesh
Apr 11, 2006 11:53 AM
maxpsi
Jun 16, 2003 01:40 PM
cr-x si
Apr 14, 2003 08:34 PM
