Zc dohc crank sprocket timing belt washers
Old Sep 25, 2023 | 05:51 PM
Mastertech2244's Avatar
Default Zc dohc crank sprocket timing belt washers
Hello! I bought a disassembled zc dohc engine in boxes. I am missing the crank sprocket washers that keep the timing belt aligned.
I can't find them anywhere.... can I use d16 sohc washers? I can find those pretty easy.
The part numbers are different on the factory diagram.
Any insight would be very appreciated!!
Old Sep 26, 2023 | 07:10 AM
jlicrx's Avatar
Default Re: Zc dohc crank sprocket timing belt washers
yes, you can use ones from the D16 SOHC, however, depending on engine years, both D16 SOHC and DOHC ZC engines came with crankshafts with different diameter front snouts (where the gear goes on) - early cranks, 88 and some 89, had a 22mm snout while later ones had a 24mm snout - make sure they match
beatthisspeed69
Jun 12, 2019 01:48 PM
90efcrx
Jun 6, 2004 10:42 AM
sporty240
Apr 25, 2004 12:57 AM
MonkeyMagic
Apr 12, 2004 06:40 AM
90hatchsi
Feb 26, 2004 03:22 PM
