seafoam idea
Old Sep 24, 2023 | 05:40 AM
youstolemybeer's Avatar
5 Year Member
Default seafoam idea
1995 civic lx 5spd
so at 432k miles my little d15b7 is starting to blow blue smoke when its over 3500 rpm. Not a lot but noticeable in the rearview mirror.
I know some folks dont care for seafoam, but here is an idea.
pull the plugs
bring one piston to bottom dead center. pour 1/4 can of seafoam into the plug hole.
attach air compressor line to compression gauge. set compressor to 50 psi threaded into spark plug hole
let it sit for 30 minutes to push the seafoam past the rings then repeat for each cylinder
after 30 minutes remove seafoam by hand cranking engine
change the oil
The compression is 135 at all 4 cylinders so Im thinking that I have some stuck oil control rings, at this many miles it would not suprise me
what do yolu think
Old Sep 24, 2023 | 05:57 AM
Chance EG's Avatar
Default Re: seafoam idea
I don't think seafoam is going to help here.
I think this is natural mileage on the engine.
Old Sep 24, 2023 | 07:24 AM
Ryanthegreat1's Avatar
432k? It's probably worn out. Oval cylinders with no crosshatch left and no ring tension.
Valve guides are probably hotdog down a hallway loose.
Old Sep 24, 2023 | 09:08 AM
5 Year Member
The head was replaced 2 years ago. The crosshatch was still present as for the cylinders being oval, Im thinking more football shaped.
Old Sep 24, 2023 | 10:54 AM
You can probably skip the compressed air. That seafoam will probably run around rhe rings and into the sump in fairly short order.
Rotate 90 degrees past tdc and all the pistons will be a mid stroke. Pour in the magic sauce and check back in 30 minutes. I bet it will have all leaked down in that time.
Old Oct 8, 2023 | 01:45 AM
5 Year Member
sooo I let the seafoam soak for 2 days, every couple of hours I twisted the crankshaft a few degrees back and forth. I then changed the oil and filter. Filled it with Rotella 15-40. Obviously the oil burning is way less d/t the thicker oil. The plan is to use the diesel oil for 3000 miles and let it clean the ring lands and what not. So far I have 200 miles on it and the oil is getting dirty quick. Previously with 5-30 Castrol, the oil would start getting dirty at about 400 miles. So that tells me that the Rotella is cleaning something out
We shall see
Old Oct 8, 2023 | 05:42 AM
Chance EG's Avatar
Or that you've further damaged the sealing on your ringlands and you're now rubbing away material at a faster rate.
Good luck, hopefully something works out.
Old Jan 4, 2024 | 12:30 AM
5 Year Member
We shall see
SOOO, 3000 mile oil change, in the 3000 miles it burned 2.5 quarts, a little better than the 3 quarts that it used to. Oil is not Rotella 10-30 with new oil filter. We are seeing progress, a very small amount of progress but still progress. The oil that came out was really icky black where as previously it was a brown black, that tells me the rottela is cleaning something, more resutls in 3000 miles, stay tuned
blackeg
Sep 18, 2011 09:09 AM
YoWTF
May 27, 2010 10:39 PM
shifty35
Mar 21, 2010 09:26 AM
jworkman21
Jul 16, 2007 04:01 AM
Gsir8
Jun 4, 2007 10:55 AM
