Need help to rewire the postive cable wiring. Can someome answer me the below.
Both wires coming off the pos+ terminal, one I think is to starter and the other goes to the fusebox T1 connection.
1 - Can we reverse the cables to the fusebox, T1 on the left goes to batt + and the T102 comes from alternator ? (By reverse I mean swapping T1 to T102) I guess amps will flow the other direction.
2 - Are both wires of the same gauge ?
3 - Can we run wire from alternator output to battery positive directly and any pros and cons to it in the long term ? This was suggested by a technician but I doubt that.
