Serpentine Pulley stops spinning after rev
Old Sep 10, 2023 | 04:13 PM
xxsniperlord68's Avatar
Default Serpentine Pulley stops spinning after rev
I took a video (linked) under my engine bay because I heard a strange noise after I had revved.
I saw one of the pulleys (i think that’s what they are called - i’m referring to the circular things that spin the belt) completely stop spinning after I revved and then go back to spinning when the revs dropped back down.
I think it’s only a real problem when I rev, and not when I slowly climb rpm’s. The belt was also changed around 8,000kms ago.
I need to find out why this is happening so that I can fix it. Also I don’t know the name of that pulley if someone can fill me in on it.
Let me know what you guys think I should do to fix this, and also what part is not working properly.
video link vvvv
picture of which one i’m talking about vvvv
*it seems like it’s the bottom left pulley
Old Sep 10, 2023 | 04:32 PM
Ryanthegreat1's Avatar
Default Re: Serpentine Pulley stops spinning after rev
You mean the AC compressor?
That's by design. It has a load, RPM, pressure, and temprature cut out.
Old Sep 10, 2023 | 04:35 PM
That's by design. It has a load, RPM, and temprature cut out.
Thats by design? I never heard that noise it made before when it kicked back in. It also shot out a dust cloud, is that supposed to happen? My a/c was on during this, tomorrow I’ll try it again without the a/c on.
Old Sep 11, 2023 | 08:01 AM
spAdam's Avatar
Loved
Community Favorite
Yes, it's by design. That is exactly what you want an AC compressor to do. Dust and noise is a different story.
The clutch and/or coil are wearing out and heading toward failure if you are dumping dust and making noise with operation. The are not expensive or hard to replace. If you get creative you can get in there and replace the clutch without removing the compressor (and hence, having to evacuate/recharge and replace the dryer).
crxaddikt
12
Sep 22, 2014 01:37 PM
Atomic1
Aug 29, 2010 08:32 AM
PR8urVtec
Aug 24, 2010 11:24 AM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jun 6, 2010 08:39 PM
JDM H22
Honda S2000
Nov 20, 2008 07:18 AM
