K swap or sell the ITR??? what would you do?
Old Aug 11, 2023 | 06:28 AM
itr1244's Avatar
Default K swap or sell the ITR??? what would you do?
I own a 2001 ITR since brand new..
long story short the crank got damaged and it can't be fixed.. it needs a new bottom end. which is near impossible to find.
now K swap seems to be only logical solution but i have no knowledge when it comes anything K and there's no honda mechanic near where i live.
im running out of energy and motivation to fix the car.
what do you guys think i can get for my 2001 CDM ITR ( im the original Owner) 150000 km
Last edited by tech8; Aug 11, 2023 at 06:51 AM. Reason: WTB deleted. This is not the marketplace.
Old Aug 12, 2023 | 02:35 PM
hybridnorth's Avatar
Default Re: K swap or sell the ITR??? what would you do?
Repair the engine, if it's and 01 CDM ITR that's a unicorn.
If it spun a bearing the gsr crank is similar and the rods are the same. Im in BC Canada and just rebuilt my motor for my itr using a used crankshaft, new OEM rods and pistons.
K swap would ruin the car unless you decided you want to modify it further (if it's all original then try to keep it that way, but your car your choice)
Old Aug 17, 2023 | 07:04 AM
itrdave's Avatar
Do what it takes to repair engine or find good JDM B18C5. Realize easier said than done, but this is critical stuff here. If it was me, I would K-swap as absolute last resort (which should not be required at this point in time).
Old Aug 17, 2023 | 01:11 PM
Klasse's Avatar
As above, rebuild a JDM short block? Or use the whole engine.
Old Aug 18, 2023 | 04:33 AM
itr1244's Avatar
This block was already damaged before and repaired once before. i spun rod bearings and had to get them rebuilt. this block already has forged pistons and connecting rods and it's all chewed up and can't be repaired.. T_T
They are going for stupid price now days.
i might eventually go K but i hate to do that to my car.
that would be the right thing to do but they want crazy amount of money for any B series engine now days.. specially the type r ones..
so i found a bare B20B block with crank. im gonna have to go with B20 vtec .. i will have to get some pistons and connecting rods for it. and hopefully it will work out.
thanks for your reply guys..
Old Aug 18, 2023 | 01:20 PM
Klasse's Avatar
B18CR will never be cheaper than they are right now...
It's just a reflection of the value of the cars. But a B20 is a nice middle ground!
Old Aug 22, 2023 | 07:04 AM
MyspaceTOM's Avatar
Honda-Tech Member formally known as TomsEF
As great as the K is, 01 CDM ITR needs a B. Hope you are able to gather some parts to get this thing back together.
Old Aug 22, 2023 | 10:48 AM
Chance EG's Avatar
Ya'll care a lot more about purity than I would with these.
Old Aug 22, 2023 | 03:55 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
original owner? Yeah, it’s worth more restored, at this point.
Unless OP has trashed it, but even then, it’s probably still better to restore the car and keep it as original as possible.
Old Aug 23, 2023 | 02:21 AM
Chrisfrom1986's Avatar
I would drop a single cam into an R before I did a k swap.
Old Aug 23, 2023 | 04:26 AM
Chance EG's Avatar
Yeah but we've always known you're a bit squiggly in the head.
Old Sep 11, 2023 | 06:41 AM
itr1244's Avatar
i found a jdm b18c..... i will keep it posted
thanks
Old Sep 11, 2023 | 07:59 AM
MyspaceTOM's Avatar
thanks
Great to hear!
db_de_luxe
Jan 28, 2012 12:01 PM
aspeed
14
Jun 23, 2004 01:21 PM
Ex-ITR5874
May 14, 2003 10:31 PM
Yellow Dragon
Jan 14, 2003 09:33 AM
96civich22
Jan 2, 2003 08:04 PM
