Speedometer inaccurate 95 Prelude Si Auto
Old Aug 9, 2023 | 08:07 PM
Caslone88's Avatar
Default Speedometer inaccurate 95 Prelude Si Auto
So I just picked off a 95 Prelude Si with 56k miles. Car is in excellent shape. With its age it does have a few minor things to be corrected. My biggest issue is the speedometer. I test drove it and never went over 40 or so I thought. Took the freeway to get home and the car said 65mph but my wife called and said I was doing 90mph. It is off pretty much from 15mph+. The tach and odometer seem to work fine. The abs light is on code 1. Car is automatic. Has anyone encountered something similar to this? Simple fix? Any help would be greatly appreciated.
Old Aug 9, 2023 | 08:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Speedometer inaccurate 95 Prelude Si Auto
What size tires are on the car ?
Old Aug 10, 2023 | 04:08 AM
Caslone88's Avatar
Factory rims and tire size. 205/55/r16
Old Aug 10, 2023 | 11:28 AM
Caslone88's Avatar
Is there any chance the VSS could be off and causing this issue?
Old Aug 10, 2023 | 08:38 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Unlikely. I am unaware of any VSS sensors from another application that would FIT on the Prelude transmission. I am not sure how you have concluded that the Odometer is functioning properly... but IF you used a GPS, drove on the Interstate at a GPS indicated 60 mph... and when the Odometer hit zero on the tenths... start a timer. If exactly 60 seconds later, the Odometer hits zero again, then your problem is a bad speedometer gauge. You will have to either have it repaired or replace it.
Old Aug 11, 2023 | 03:31 AM
Caslone88's Avatar
So when I used my gps watch I pretty much set the trip to 0 and started my watch. They tracked pretty dang close to each other. One wasn’t falling behind the other. I will try your suggestion of doing it later on this evening and see what happens. I called a local place that repairs/restores gauges for old high end cars and they said they don’t work on Japanese brands due to no parts availability. Would you happen to know if anyone that repairs them just in case it is the speedometer?
Old Aug 11, 2023 | 08:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I do not. I would replace the instrument cluster with one from a salvage yard or online source.
Caslone88
Aug 9, 2023 08:01 PM
Prelude_si17
Sep 15, 2009 12:23 AM
beav
Dec 11, 2005 09:55 PM
H23A1LUDE
Jun 29, 2002 09:34 AM
