Battery cuts when going into odd number gears (1st,3rd,5th)
Old Aug 9, 2023 | 06:49 PM
Arodriguez562's Avatar
Default Battery cuts when going into odd number gears (1st,3rd,5th)
I’m having a issue where whenever I shift into the odd numbered gears I see my clock turn off and lights on the dash turn off too but whenever I shift it into 2nd 4th or reverse it doesn’t do it. I relocated the battery to inside the car but still having the same issue. I look under the car and move my shift linkage around and it’s not hitting anything. Any ideas on where to start ??
ef hatch b20b ls tranny hasport shift linkage with skunk2 short shifter and ****
Old Aug 10, 2023 | 05:03 PM
Default Re: Battery cuts when going into odd number gears (1st,3rd,5th)
https://www.reddit.com/r/civic/comme...t=1&utm_term=1
this is a Reddit post with the video showing the lights turning off can’t post video here
Old Aug 11, 2023 | 06:08 AM
TacoCat's Avatar
5 Year Member
My guess is you have a grounding issue. Shifting into reverse engages the revers switch on the trans which could be completing the circuit. Try unplugging the reverse switch and see if the behavior changes. If so, I would start chasing grounds.
Alicali
Nov 30, 2016 09:23 AM
Costco
Transmission & Drivetrain
Jun 22, 2011 10:57 PM
Lokisdope
Apr 1, 2008 11:29 AM
bOOsted_D16
May 17, 2006 04:28 AM
aeon
May 6, 2004 09:36 PM
