CTR and Civic EJ Coupe spindle size?
So, I have a 1999 civic coupe EX with a 4 lug. I'm working on a project to convert this into a 5-lug vehicle and eventually swap out a D16Y8 motor to a CTR B16B paired with the S4C tranny. Upon research, I noticed that CTR uses a 32 mm spindle nut and some youtuber said EX and CTR use a different spindle which requires a JDM knuckle. I don't have a tape measure, so I do not know if they are different in diameter. Does the CTR 5 lug hub only fit on CTR front knuckle and rear trailing arm or slide into a knuckle that's already on the EX coupe?
Incorrect in 2023 - This is the way, for the rear: https://honeddevelopments.com/produc...r-hub-nut-kit/
OP, you kind of flip flop between you questions about fronts and rears so I hope I can address them successfully. For the fronts on an EX, you do not need to swap knuckles (spindles are a rear component). Press in a USDM ITR hub with a fresh bearing and you’re done.
boostincoupe
26
Dec 21, 2002 10:21 PM
