Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Help! Very low compression after clutch replacement
Old Jul 26, 2023 | 12:37 PM
rygro's Avatar
Default Help! Very low compression after clutch replacement
Hello,
My 2009 Civic SI recently had clutch issues to the point where the car would barely move anymore. The engine was still running fine but I had to get it towed it to a local mechanic shop. They confirmed the clutch was the issue so I had them replace it. After a few days they called and told me the clutch was done but the engine wouldn't start. They did some compression tests and said it had only 30psi across all cylinders now. Their solution was to replace the engine because a used engine would be cheaper than stripping the engine down to locate and fix the problem. They assured me that one thing had nothing to do with the other and it's just a coincidence.
So my question is, could they have accidentally messed up the timing or anything else during a clutch replacement?
Thanks,
Ryan
Old Aug 3, 2023 | 08:43 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Help! Very low compression after clutch replacement
It's always possible. And it's also interesting they want to do an engine swap. No evidence left for you to see if there was something awry that way.
I did the clutch on my 2007 Si myself and it was a long 8 day process. I really can't think how they could cause 30 psi on all 4 from doing a clutch job, but I also can't say it's not possible. The engine is supposed to stay in the car and be supported while only the transmission comes out. If they pulled the whole thing, who knows what was done.
If you do let them do the swap, keep the old engine, it's worth a bit, especially the RBC intake manifold and the head itself.
Old Aug 14, 2023 | 11:21 AM
rygro's Avatar
It's strange for sure. Have the car at home now and going to start tearing it down and see for myself.
Thanks.
eman96
Sep 4, 2015 06:31 AM
mashed_taters
May 26, 2012 02:05 PM
Mattgrimes
53
Aug 30, 2009 04:00 AM
whagkangmakulet
May 11, 2003 08:57 AM
