'93 Prelude - Need additional troubleshooting ideas
Old Jul 24, 2023 | 08:30 AM
shumandoodah's Avatar
Default '93 Prelude - Need additional troubleshooting ideas
1993 Prelude 2.2L L4 DOHC
Car ran without issue.
Plugged it into a battery tender for a couple of months.
Couldn't start as the battery was completely dead. LIke dead dead. The functional battery charger would not even turn on.
Replaced the battery.
Accessories all work with turning of the key.
Turning the key will not engage the starter.
I have jumped the starter and it is operating fine.
There is an issue somewhere between the physical key/ignition and the starter.
I have visibly inspected all fuses and they appear ok.
Are there some other things I should be checking?
Old Jul 24, 2023 | 09:33 PM
TimiK's Avatar
10 Year Member
Default Re: '93 Prelude - Need additional troubleshooting ideas
Check fuses and grounds.
Ignition control module inside the distributor?
Ignition switch?
Main relay?
new capacitors for ECU (there is capacitor kit for that)
Old Jul 25, 2023 | 07:29 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Is this an automatic or manual?
Old Jul 26, 2023 | 02:14 PM
@tech8 , it's a manual.
@TimiK , Thanks for the ideas, I'll start working down that list.
Old Jul 26, 2023 | 03:08 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check to see if the clutch interlock switch stopper pad is still there. It may have deteriorated.
That can make your car not start.
https://www.google.com/search?client...h=721&dpr=1.25
uNF$@#!
Jan 8, 2021 08:31 PM
jgett002
Aug 3, 2016 02:00 PM
Bruce Banner
Apr 12, 2007 12:49 PM
rewerbcrx
Jan 13, 2007 12:12 PM
eric416
May 29, 2006 03:23 PM
