Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Car CEL with Evap Code P0453
Old Jun 26, 2023 | 09:23 AM
hayeltaehs's Avatar
Default Car CEL with Evap Code P0453
Hello everybody in this thread, I have a 2011 Honda Civic EX with a CEL (Check Engine Light) that first came up after I took the car to a mechanic to do Throttle Body Cleaning.
Please keep in mind I never had a CEL ever before the mechanic performed the service for me.
I scanned it with a really cheap OBDII Scanner and found that code P0453 is showing up.
After research, I found it was some sort of EVAP Code which says that the Fuel Pressor Sensor is reading too high which I am really confused about because the mechanic only performed Throttle Body Cleaning and nothing else.
I tried clearing the code. It works for a short period of time. But after two or three complete engine crank cycle's, the CEL and code p0453 comes back unfortunately.
I already replaced the EVAP Purge Valve Solenoid but the code is still coming up for some reason.
I talked to the mechanic but he seems like he is an a**hole and doesn't want to take full responsibility for this as this CEL and code came up for the very first time right after he performed the work. Long story short, I am never coming back to him so I really need some help with this because my inspections for this car is due.
Thanks everyone in advance!
Old Jun 27, 2023 | 12:07 PM
hayeltaehs's Avatar
Default Re: Car CEL with Evap Code P0453
bump
Old Jul 13, 2023 | 06:35 PM
jul059's Avatar
Have you replaced it with OEM? The cheapest aftermarket I could find lasted about 300 miles.
civicb16eg
Jan 5, 2010 01:23 PM
97civic123
Jul 13, 2007 04:14 PM
t_dot_SiR
May 2, 2007 04:01 PM
ActiveAero
Jan 18, 2002 11:14 PM
