Is my catalytic converter clogged?
I kicked it ...and tapped on it ....no rattling ....at start up it still has condensation as it normally should . At full tempature ....and after very spirited riding ....it seems to be at a normal warmth .....no overheating.
but after i readline it thru a few gears ...i get this smell in the cabin like a skunky fart .....is this a possibel sign of a clogged Catalytic Converter , or do i possibly have an exhaust leak .
i have a JDM DC 4-1 header ....and Apex'i N1 exhaust ..it could be possibel its leaking for the flez flange ...but its kinda hard to tell .....
is the smell normal ...or has this ***** gone bad ?
This is a work friendly board, please be a little more mature with the thread titles.
I didn't dock any percentage. This time.
could be the Catalytic Converter, Its no good when your low on oil.. also im sure you alrady have.. make sure your ebrake not locked up... could be a few things causing a bad smell. Also if you ricers stinkn when you burn them
oRgy - who is at work right now.
i just changed the oil .....and yes i use mobil one ...but the oil level is fine ...
if your cat was clogged ....trust me you would know......the car would shudder as if it was going to stall. Dont worry bout a clogged cat unless you have like more than 100,000 miles
How can that thing support itself when it walks? I bet it looks funny when it does though huh?
That must be an American cat, because most Americans are kinda fatttt...(so I heard)...
i'll out-skinny you any day son
SiR-G DC
Aug 24, 2008 04:31 PM
JunIntegra
May 2, 2003 10:09 AM
