Valve adjustment question
Old Nov 18, 2002 | 11:51 AM
Austin's Avatar
Default Valve adjustment question
How in the hell do you guys correctly adjust you valve lash when you have your cam gears set at X degrees, and you have you head milled Y inches...example I have my cam gears set at +5, +5(cam degrees)...I have a Mugen head gasket which retards the cam timeing ~1.5 degrees, so my net cam gear settings are at +3.5, +3.5...now I'm trying to line everything up for a valve adjustment and it starts to get a little complicated.
So...how do you do a valve adjustment?
Austin - who is leaving for lunch now
Old Nov 18, 2002 | 11:55 AM
Bbasso's Avatar
Default Re: Valve adjustment question (Austin)
Just my thought could be wrong or right, let me know
If everything is properly set up and working with the motor then don't ya just lift the piston to TDC and check the gap?
Old Nov 18, 2002 | 12:01 PM
CPR's Avatar
CPR
Here's a thread that answers the part about cam gears.
https://honda-tech.com/zerothread?id=223340
Old Nov 18, 2002 | 12:46 PM
baonest1's Avatar
Default Re: Valve adjustment question (CPR)
well damn, its answered my Q..
Old Nov 18, 2002 | 12:50 PM
Chris's Avatar
Ahh yes.
Its easy! I think we sometimes read too much into directions or take them too literal sometimes.
All you have to do is make sure that the lobes for that given piston are not pushing on the valves, ie "lobes up".
Dont even worry about the cam location... just look at the lobes, and ask yourself "Are they up?"
I dont know why I didnt think of that yesterday.
Old Nov 18, 2002 | 01:13 PM
Austin's Avatar
Default Re: Valve adjustment question (Chris)
Because it's to simple of an answer, I mean things can't be that easy
Old Nov 18, 2002 | 01:20 PM
yoshi234's Avatar
I shoot brides
Is there any other way to do a valve adj?
yshi - whose leaving work in two hours to go to my first class towards becoming a real honda tech
#Leo#
May 10, 2010 12:26 PM
Gump
Sep 20, 2004 03:09 PM
91integraLSVTEC
Aug 22, 2003 08:54 PM
Comptech98GSR
Aug 2, 2002 12:28 AM
94GSRNewbie
Jul 26, 2001 11:06 PM
