Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
pilot wont start
Old Jun 9, 2023 | 07:04 PM
firsttimepilot's Avatar
Default pilot wont start
ive had the 2007 pilot for only a month. it was running quite well until recently. to complete my registration i am required to pass a ca emittions test. any sign of warning light will cause a fail. i was seing a vsa light with a triangle light . i found a youtube video to correct the by using a jumper wire between two pins on the data terminal below the dash. i thought the directions were followed as described, but i didnt get the response on the dash lights like described in the video. since then the car wont start, and my scan tool (xtool d9) will not communicate with the car. it doesnt recognize the vin number and shows a can not communicate with the ecm. . before i bite the bullet and take it to a real mechanic. can anyone give me something that i might try.. i have tested the fuel delivery system and confirmed the pump is working and the pressure seems good, if i jumper the power directly to the pump. but there is no power to the fuel pump relay below the dash. is this one of the security-smart key protocols? any help is appreciated
Old Jun 13, 2023 | 06:22 PM
Ericks's Avatar
Default Re: pilot wont start
Sounds like you fried your computer you not supposed to jump nothing on dlc or obd port and that trick only worked for old gm vehicles for gathering codes though
Old Jun 14, 2023 | 07:55 AM
yeah, i thought something was fried, too. and it was, but only a fuse. . i had disconnected a fuse for a parasitic drain, when i connected the fuse, i noticed the antitheft system was activated and then found a blown fuse . fuse replaced, all is well. thanks for taking the time to reply.
joe.s
Honda Civic (2001 - 2005)
Jun 23, 2018 10:04 AM
Tim Larkin
Jan 19, 2016 01:42 PM
DO-WORK-SON
Jan 23, 2014 10:49 AM
BobbyRodriguez
Oct 10, 2011 06:41 PM
spencerxfr3sh
Feb 11, 2009 11:49 AM
