Del sol Speedo issue
Old Jun 4, 2023 | 07:48 AM
Mo0nShad3's Avatar
Default Del sol Speedo issue
Hi there, I'm having an issue with my del sol 1992 where the Speedo doesn't work on the dash. There is no check engine light on. The rpm, fuel and temp all works fine however the speed doesn't move at all.
I first suspected the speed sensor or the connector to that however there is continuity from the dash connector and speed sensor connector. Same with ground.
Any help with this is appreciated so thank you in advance.
Old Jun 4, 2023 | 07:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Del sol Speedo issue
Does your odometer work ?
Bipolarcivic
12
Mar 27, 2016 03:34 PM
Dripp_City
Oct 30, 2013 01:18 PM
m1ch431_g
Jan 23, 2006 11:58 AM
b16aEGcivic
Mar 27, 2004 09:32 AM
ckdelsol
Audio / Security / Video
Nov 11, 2001 07:28 PM
