Service connector won’t work!!!
Old May 31, 2023 | 07:08 PM
Boosted_brandon's Avatar
Icon4 Service connector won’t work!!!
So recently I hooked up rolling antilag to my service connector I only used it twice.. after that it didn’t work so I took it off because my old motor broke the pump so I took it off to refresh it. Then I just recently put the motor in.. so I wanted to check ignition timing but when I jump the connector the CEL won’t go on.. even when I turn the key to the on position… the CEL won’t show on the dash Ik the Custer and ecu is fine because i Tested it in a buddies car I checked all fuses.. idk what els it can be I’ve been trying to figure out this issue for the last 3 days and can’t get it to work
car is a 1997 ek coupe
engine management s300 v3
before anyone says that you can’t jump the connector with the s300 you can because I’ve done it to a lot of cars
Fancybear
Jan 28, 2018 07:58 AM
1997civicex
18
Apr 22, 2009 12:42 PM
M2B4
Jul 8, 2007 01:43 PM
Lucky-13
Mar 21, 2007 01:54 PM
b18bcrxhf
Dec 31, 2006 11:13 AM
