D15B7 or D16 tranny for D15B manual swap?
Hello, I have a 1992 Honda civic dx D15B engine with a automatic transmission. I want to manual swap it, But im having trouble figuring out what transmission to get. I can only seem to find D15B7 and D16 manual transmissions at the junkyard. Do i have to get a D15B7 tranny for it to work? Or can i use a D16 tranny on my D15 without modification? I want it to be as bolt on as possible. Sorry if i suck at explaining the situation, but id really appreciate any input. Thank you !
Any D series manual transmission from '92-95 will work as far as being "Bolt Up". You will have to do wiring at the shifter, add manual brake and clutch pedals, shift linkage, and clutch hydraulics.
Oh okay i see, In that case ill keep an eye out for the y8 or z6 since that's what I've heard are the shortest gear ratios. Do you happen to know where i can find exactly what id need to get for the swap? Transmission,Linkage,Pedals ect..? Id appreciate a link or something, again thank you.
christianc5692
Sep 5, 2010 06:17 AM
bean0renx
Honda Civic (2006 - 2015)
Apr 18, 2008 01:17 PM
