Wheel hub
Old May 16, 2023 | 04:59 AM
my97accord's Avatar
Default Wheel hub
My OEM rear wheel hub/bearings were noisy, so bought a set from Autozone and installed them. Honda manual says to torque spindle nut to 134 ft/lb. The issue that I am having is... even at 100 ft/lb torque, the wheel hub get super tight and does not rotate. What am I doing wrong? I ended up loosening the spindle nut so that the wheel turns. Please advise.
Old May 17, 2023 | 04:49 AM
my97accord's Avatar
Default Re: Wheel hub
bump
Old May 17, 2023 | 01:11 PM
LukeM's Avatar
5 Year Member
No chit it gets super tight, 135 pounds is a lot of force. Crank on the nut until your torque wrench reads 135 pounds. Simple as that.
Old May 19, 2023 | 08:23 AM
my97accord's Avatar
Not sure I understand... are you saying torque it to 134 ft/lb even though the hub barely turns?
Old May 19, 2023 | 01:42 PM
LukeM's Avatar
5 Year Member
There is something wrong if the hub won't spin. Closely compare the old and new hubs and double check you install process.
Old May 20, 2023 | 02:40 AM
my97accord's Avatar
This is for rear wheel hub assembly, it is easier than an oil change. just one axle nut to remove and replace. I removed and regreased EOM hub on this car few times in the past, never had any issues with those(they have become noisy lately). Will remove and inspect this weekend.
davidmendoza742
Dec 4, 2021 08:35 PM
Piotras
Honda CR-V & Element
Apr 15, 2021 04:46 AM
YoungKadafi
Suspension & Brakes
Mar 10, 2007 05:06 PM
navin
Dec 9, 2004 04:54 PM
underpressure02
Nov 12, 2003 06:14 PM
