Running Rich
Old May 15, 2023 | 10:15 AM
frankin97's Avatar
Default Running Rich
I bought a 97 civic lx that some one did a engine swap in. The engine is a 93-95 D16Z6 with a newer 97-99 intake manifold and a 97 manual tranny. The ECM is for a 97 manual and the wiring harness. The car starts and runs, but it runs really rich. I put a different harness in it because the other one was hacked together. I don't know if their are any wires that need to be spliced together or eliminated. The only ones I did were the two for the crank sensor. Any help would be appreciated.
Old May 15, 2023 | 11:46 AM
Chance EG's Avatar
Default Re: Running Rich
You should be using a P28 ECU for that engine.
Old May 16, 2023 | 10:43 AM
frankin97's Avatar
So get a P28 ECU and the jumper and everything will work fine
Old May 16, 2023 | 01:32 PM
spAdam's Avatar
Loved
Community Favorite
Hang on. The ecu - it's from a 97 manual what? Is it a P2E or P2P? What harness did you put in with the replacement engine?
Old May 16, 2023 | 03:55 PM
frankin97's Avatar
I didn't do the replacement, I bought the car that way. The ecu is a P2E-A02. The car drives fine it just runs really rich
Old May 16, 2023 | 07:52 PM
spAdam's Avatar
Loved
Community Favorite
Perhaps in part because the ecu is calibrated to 190cc injectors and the engine has 240cc, about 25% larger.
You need a 96-98 P2P ecu. It will plug in and should run the car reasonably.
Not necessarily THE problem, but it’s A problem.
Ekked
Nov 16, 2021 06:07 AM
slvrslepr
Mar 23, 2009 02:58 PM
ekmaniac101
Audio / Security / Video
Feb 5, 2009 07:23 PM
akteamster
Nov 6, 2005 09:10 PM
CGS
Oct 26, 2005 03:17 PM
