Rear compensator arm and accessing the captive nut
Old May 11, 2023 | 12:29 PM
JCTyler's Avatar
Default Rear compensator arm and accessing the captive nut
I'm curious as to how this section of the trailing arm system of the rear suspension is attached. The area where the captive nut is located, is it just a welded cup on the chassis to locate it? Any insight into how this is assembled at the factory? Has anyone tried with success another method apart from drilling into this area to remove the nut and bolt, when replacing the lower compensator arm?
Old May 11, 2023 | 12:55 PM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Default Re: Rear compensator arm and accessing the captive nut
Another method for what?
Is yours stuck?
What year and model are you working on?
Have you looked at the FSM?
Old May 11, 2023 | 01:37 PM
JCTyler's Avatar
Another method of getting to the captive nut, to clarify. Whats the the FSM? 1999 Civic Si Coupe Canadian Spec.
Old May 11, 2023 | 03:39 PM
Chance EG's Avatar
Why do you need to remove the nut from the assembly? I'd wager the only way would be to cut, and then later reweld.
If the slider is seized and you can no longer adjust it, you can get compensator arms with adjustable end links like Hardrace.
Old May 12, 2023 | 08:51 AM
Premium Member
Loved
Community Favorite
Hey JC - the FSM is the Factory Service Manual - all kinds of good stuff in there, lot of pictures.
I am 5th Gen, so I don't have a manual for '99, but I bet others on here can help you find one.
JCTyler's Avatar
I'm thinking I'll need clean the nut to put the new bolt in from seeing youtube videos. Possibly cut put the old bolt. My cars pretty rusty exposed to Canadian winters and its going to be a delicate job. If I use an impact gun, loosening the bolt will I destroy the captive nuts mount? I'm trying to figure how it sits in the frame and what holds it place. How does it attach and how does it function?
Old May 12, 2023 | 08:54 AM
JCTyler's Avatar
Ahh I am using the FSM as a gude to all this. Its just that its the PDF copy and some of the image details are a little hard to interpret when you're trying to determine things in the real world.
Old May 12, 2023 | 08:58 AM
Premium Member
Loved
Community Favorite
Good stuff if you are using the FSM.
Rust sucks!
Use the Force (and lots of Kroil/PB Blaster)...
Old May 12, 2023 | 09:15 AM
Chance EG's Avatar
Impact gun would actually probably be better than just using a breaker bar or big socket wrench.
Soak it in penetrating fluid for 10-15 minutes before hand, and then give it another little blast before you zap it off.
Old May 13, 2023 | 07:14 AM
JCTyler's Avatar
Heres a screengrab of the nut. Any idea if theres a Honda part number on this? checked the manual and Hondapartsdirect. No luck.
Old May 13, 2023 | 01:07 PM
Chance EG's Avatar
Can you zoom out a bit and take a few more pictures from further back?
That second picture is of what looks like an access hole you cut?
Old May 13, 2023 | 04:45 PM
tamboo's Avatar
10 Year Member
https://bobistheoilguy.com/forums/th...ze-mix.249189/
Old May 13, 2023 | 09:58 PM
JCTyler's Avatar
Those are screengrabs off Youtube for the captive nut from other people
Old May 14, 2023 | 06:40 AM
GIZZ - EXV's Avatar
Loved
I'd cut the view hole and perfect use for induction heater coil. I'd rather save it than bust up the metal all around it. But if it's everything is rusted you'll have to fab it all up.
https://amzn.to/42BaXwb
Graybeard327
Honda CR-V & Element
Jul 16, 2017 06:42 AM
R00teg
Suspension & Brakes
Jul 16, 2009 02:05 PM
Steven.
Aug 5, 2008 01:09 PM
Civic1992DX
Mar 23, 2003 06:10 PM
Kolijian
Jan 13, 2003 10:37 AM
