Power sliding door issues - 09 Odyssey
Hello all,
My passenger sliding door has an issue with one of the actuators. If you use the remote or dashboard buttons to open or close the door, it jolts for a second, then retreats, and beeps 3 times. If it was closed and I open it, it will re-close and lock. If it was open and I try to close it, it will jolt, and remain open. If I do it with the handle, I get the same result. However, if I give the handle a bit of a tug to open or close it, it works and moves along just fine. It seems like there is an actuator that holds the door open or closed to prevent the door from sliding on it's own if you're on a hill. It sounds like it's trying to get passed that, but can't.
I can't find any information on which actuator to replace or inspect other than the door lock one.
help
help
Intercooler
Nov 18, 2004 08:43 PM
