Civic 2000 Injector 3 short and flooding the engine
Old May 8, 2023 | 08:19 AM
Hasan Khurshid's Avatar
Default Civic 2000 Injector 3 short and flooding the engine
Hi
I want to know what can be the reasons for a short in the wiring only for injector 3 and how I should approach the diagnostic of this?
Thanks.
Old May 8, 2023 | 08:52 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Civic 2000 Injector 3 short and flooding the engine
The ground wire between the ECU and the fuel injector is likely touching something metal... essentially creating a CONSTANT ground. If you try another ECU to make sure that the injector drivers aren't damaged, then the grounding is the issue. You can temporarily use a test wire between the ECU pin and the fuel injector in question, clip the wire within three inches of each clip and twist in the test wire. You should be good to run then. If this fixes the issue, then you can permanently replace the wire and move on.
Nt03hamlin
Classic Hondas
Mar 22, 2011 06:17 PM
92civtegra
Jun 30, 2010 07:09 PM
seanc520
May 23, 2010 01:47 AM
