ZC non vtech motor JDM ???
Old May 6, 2023 | 07:30 PM
Civic850's Avatar
5 Year Member
Default ZC non vtech motor JDM ???
I have a 91 civic dx hatch non vtech and thought it was a D16 but apparently it’s stamped ZC and from what I have researched it’s JDM ??
Old May 7, 2023 | 07:33 AM
jlicrx's Avatar
Default Re: ZC non vtech motor JDM ???
if it says ZC, then it is JDM
Old May 8, 2023 | 04:20 AM
Civic850's Avatar
5 Year Member
Originally Posted by jlicrx;[url=tel:52716511
52716511[/url]]if it says ZC, then it is JDM
I’m so confused it’s stamped ZC but it has a SOHC black valve cover so when I purchased it I automatically assumed it was a d16 whatever
Old May 8, 2023 | 04:22 AM
Civic850's Avatar
5 Year Member
Old May 8, 2023 | 05:52 AM
jlicrx's Avatar
see attached
File Type: pdf
Old May 8, 2023 | 06:23 AM
Civic850's Avatar
5 Year Member
Originally Posted by jlicrx;[url=tel:52716797
52716797[/url]]see attached
thanks a million for your help but still not certain which one is mine according to the link it’s either OBD0 SOHC which I originally thought it was because it states the mpfi that mine has but still confused because also states that the DOHC has a black valve cover with 4 bolts on the ouside of the cover which mine also has soooooo……..
Old May 8, 2023 | 02:46 PM
jlicrx's Avatar
is that last picture you posted your engine? that is an OBD0 non-VTEC SOHC ZC (if it says ZC on the block) with the stock DPFI intake manifold from the 88-91 Civic/CRX DX model - it is not MPFI - probably started out as a dual carb SOHC ZC - does it run?
this is the DOHC ZC (MPFI)
Old May 8, 2023 | 05:27 PM
Civic850's Avatar
5 Year Member
Originally Posted by jlicrx;[url=tel:52717031
52717031[/url]]is that last picture you posted your engine? that is an OBD0 non-VTEC SOHC ZC (if it says ZC on the block) with the stock DPFI intake manifold from the 88-91 Civic/CRX DX model - it is not MPFI - probably started out as a dual carb SOHC ZC - does it run?
roger that yes that’s my engine you are correct do you know if possible to swap it to mpfi what that requires and also I want to auto to manual swap it do you know what transmissions are compatible??
Old May 10, 2023 | 06:31 AM
Tyson's Avatar
ZC stamped motors came in many different flavors. It's not just DOHC 1.6L d16A9. ZC was also stamped on SOHC and VTEC engines.
​​​​​If it's SOHC and no VTEC, it could either have been carbureted or MPFI. The obvious difference will be an open port (or already blocked off plate) in the back closer to the distributor side. The cams are slightly different, and the MPFI is nearly identical to the d16A6.
Either way, the choice of intake is freely up to you and what you already have or whatever will bolt on just like a d15 can be converted to MPFI.
Transmissions will bolt on the same just like any typical D series.
ZC means 1.6 liter D series.
blueb16-em1
Aug 24, 2007 08:00 PM
chrisblack
18
Jan 27, 2005 10:08 AM
speed 1
Aug 23, 2004 10:32 PM
allmotorEG-SI
Oct 1, 2001 01:19 PM
