No crank/no start after engine swap
Old May 6, 2023 | 05:37 AM
L337RH's Avatar
Default No crank/no start after engine swap
Hey everyone!
I've got a 96 hatchback with a z6 and a 5 speed swap. I recently had a y7 with the same transmission and it ran great until the timing belt broke and the engine took a ****. I swapped it with a z6 and kept the same transmission. When I turn the key it's not wanting to even crank over. When I changed the timing belt on the old engine and it was running. I didn't realize it until it was too late but one of the injector wires had an exposed part on the wire and it touched the manifold and died instantly. I swapped the engine because the old one was dead. After the swap, I tried to get it to crank to put oil pressure back to the turbo and get everything primed and it wouldn't crank. I jumped the battery to the solenoid and it makes a starting sound like it's trying to start.
Battery tested good. The resistance at the 3 main grounds is 0.1 or 0.0, Fuses tested good with test light
When I turn the key, I get the beeps and my radio comes on and headlights work but the fuel pump doesn't kick on. I turn the key to crank it and nothing
It's like the solenoid isn't getting power
I don't have the clutch safety switch where it was Auto and everything worked before the swap.
I replaced the following:
fuel pump/fuel pump relay(the one behind the glove box)Wiring harness/injectors and the Starter
Any help would be greatly appreciated. I've searched all kinds of websites and forums and nothing has helped thus far.
Old May 7, 2023 | 09:23 AM
sirtef99's Avatar
Default Re: No crank/no start after engine swap
Check your ground at thermostat.
Old May 7, 2023 | 10:01 AM
L337RH's Avatar
That's the one for the wiring harness right?
Old May 10, 2023 | 07:19 AM
L337RH's Avatar
The fuel pump runs when I jump wires 1 and 7 together but won't crank
rollinhonda3
Nov 9, 2010 02:25 PM
rick_rabies
26
Apr 5, 2009 01:07 PM
blue89hatch
May 7, 2008 01:57 PM
SOKal
Nov 13, 2006 10:14 AM
marc-111
18
Jan 29, 2006 09:10 AM
