B16A2 transmission options
Old Apr 26, 2023 | 10:07 AM
NotSoNic's Avatar
Default B16A2 transmission options
I have a 2000 Honda civic si with a b16a2 cp 11.5 pistons and eagle rods. I installed skunk 2 tuner 1 cams and skunk 2 adjustable cam gears. s2 ultra manifold & 74mmTB hondata 4bar s2 fuel rail rc750 injectors. running a hondata tune
I was wondering what transmission would be a good choice to go with as my last one just went out and I’m worried if I get the same tranny the same thing is gonna happen again (pulled the case apart and the reverse gear started sagging enough to come into contact with other gears causing it to bind and make a hellacious noise)
Old Apr 26, 2023 | 10:28 AM
Sic_DA_Nine's Avatar
Default Re: B16A2 transmission options
rebuild it.
these are old cars.... you find another whether its another b16 trans or not, its tired and if it doesnt give you problems not, it eventually will
ochsy03
Oct 10, 2005 06:08 AM
red civic standard
11
Aug 8, 2004 08:38 PM
RangerDan
Aug 12, 2003 11:55 PM
