Car cranks but no start! Help please!!
Old Apr 25, 2023 | 11:06 AM
Lamochilera21's Avatar
Default Car cranks but no start! Help please!!
So I have a 1998 ek coupe and put a d15z6 motor on it car cranks but won’t start! I sprayed a little bit of starting fluid and it speeds up the crank but won’t start. I did the timing it’s on point
what could it possibly be.
i do have a p28 ecu with a jumper harness.
im new to this page so all the help possible very much appreciated.
Old Apr 25, 2023 | 12:24 PM
Sic_DA_Nine's Avatar
Default Re: Car cranks but no start! Help please!!
check for spark and fuel
Old Apr 25, 2023 | 01:11 PM
roddrick's Avatar
Premium Member
5 Year Member
check for spark at the wires and also inspect the components inside the distributor if no spark found at wires. Also I have seen a lot of faults with jumper harness setups and experienced them as well before.
Old Apr 25, 2023 | 01:19 PM
I got spark and fuel is getting to the injectors but just cranks won’t turn on
Old Apr 25, 2023 | 07:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
What fuel rail are you using ?
Old Apr 26, 2023 | 10:42 AM
check your timing
Old Apr 26, 2023 | 04:05 PM
A y8 fuel rail i believe
Old Apr 26, 2023 | 04:06 PM
It’s right on. Just cranks but won’t start.
check your timing
Old Apr 26, 2023 | 07:52 PM
Also right on I made sure it was on point and it just cranks but won’t start
any other suggestions?
Old Apr 26, 2023 | 09:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Make sure that you have spark. Also, after trying to crank the engine a few times, immediately check the spark plugs and see if they are wet. Just because you have fuel getting to the rail doesn't mean that it is getting into the engine. Since the engine doesn't run on starting fluid... it is likely that your problem is a lack of spark and not fuel related.
Old Apr 28, 2023 | 10:55 PM
So my spark plugs are wet I have gave spark, I tried starting it after I chained the coil on my distributor and all it did was just a loud pop, I crank it it turns but won’t crank.
Old May 3, 2023 | 11:11 AM
fryman's Avatar
Check to make sure you have the firing order correct on the spark plug wires. If you have them mixed up on the distributor cap it can cause the symptoms you're describing. I once bought a non-running D16Z6 for $300 and when I worked on it, it just ended up being mixed up spark plug wires on the cap.
No More Civic
10
Aug 27, 2002 09:35 AM
