HELP? the R is idling weird.
Old Nov 18, 2002 | 10:23 AM
stRtypR25's Avatar
Default HELP? the R is idling weird.
just recently my R has been idling at like 900-1000 instead of the normal 750-800. do you have any suggestions as to what can be the problem
Old Nov 18, 2002 | 10:27 AM
HondaRcB's Avatar
Default Re: HELP? the R is idling weird. (stRtypR25)
Does it only do it when the car is cold?
Old Nov 18, 2002 | 10:30 AM
disordeR's Avatar
it should idle between 900-1000 when the car is cold or if you are running your lights are AC.
Old Nov 18, 2002 | 10:38 AM
stRtypR25's Avatar
Default Re: HELP? the R is idling weird. (disordeR)
it idles like that when the car is warm
Old Nov 18, 2002 | 11:16 AM
tjtruong's Avatar
New User
mine does the same thing, but I haven't fixed it yet so i'll let you know when its fixed. Some solutions would be found here. Try them out.
https://honda-tech.com/zerothread?id=298981
https://honda-tech.com/zerothread?id=304013
tj
Old Nov 18, 2002 | 12:23 PM
stRtypR25's Avatar
Default Re: HELP? the R is idling weird. (tjtruong)
thanks man
Old Nov 18, 2002 | 12:32 PM
baonest1's Avatar
hmm my car used to idle high as a ****.. i just set the idle screw low, but it never worked. the screw fell out but it still ides halfway good.
Old Nov 18, 2002 | 12:47 PM
MPH's Avatar
MPH
New User
Default Re: HELP? the R is idling weird. (baonest)
You have to disconnect the sensor on the back of the throttle body then adjust the idle screw.
clemsonteg
Oct 21, 2006 09:46 PM
thisboyjulio
Sep 10, 2006 09:50 PM
Mr.Integra
Jul 27, 2003 12:14 PM
