Will 10-pin B18b distributor swap onto later 99+ JDM B20 engine?
Old Apr 8, 2023 | 03:01 PM
roninsoldier83's Avatar
Default Will 10-pin B18b distributor swap onto later 99+ JDM B20 engine?
So I’m wanting a swap in a 99+ high compression B20 into my 1998 Civic DX. I’m wondering if I need to swap to the square style distributor or if the motor will even run right if I do?
From what I can tell, it looks like all 96-98 Civics, 94-01 Integra’s and 99-00 EM1 Si B16 Civics have the square 10-pin distributor plug.
The 99-01 CRV (and 99-00 EX) has a rectangular 8-pin distributor plug. From what I’ve been reading the extra wire(s) on the 10-pin plug are RPM signal… so I think if I used a cheap 10-pin to 8-pin conversion harness, I don’t think my tach would receive the signal; which makes me hesitant to use a jumper harness.
My question is: since the B18b and 99-01 CRV B20b/z/z2 all use the same P75 head, can I just bolt on a 10-pin distributor from a B18b? Will it just work?
Anything I should be aware of?
For reference I plan on using my stock 1998 Civic wiring harness with an OBD2a Integra LS ECU.
Thank you!
Old Apr 8, 2023 | 04:19 PM
Chrisfrom1986's Avatar
Default Re: Will 10-pin B18b distributor swap onto later 99+ JDM B20 engine?
96-98 distributor.
Old Apr 8, 2023 | 08:04 PM
Originally Posted by Chrisfrom1986
96-98 distributor.
Are you saying a 96-98 distributor will fit a 99-01 B20 block?
Old Apr 8, 2023 | 09:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The '96-98 Integra LS/RS/GS (non-vtec) distributor will plug into your OBD-2A Civic engine harness AND bolt to your B20Z engine.
Old Apr 9, 2023 | 08:12 AM
Copy that, thank you!
roninsoldier83
Apr 9, 2023 08:34 PM
94EG8
May 4, 2011 03:30 PM
Vtec Civic 93
10
Aug 13, 2010 12:12 AM
.Grimace
Jan 3, 2007 11:19 AM
