B20 vtec head issues
Old Apr 8, 2023 | 12:55 PM
JDAL89's Avatar
Default B20 vtec head issues
Ok, I need to reach our to the best honda minds. I have a 92 civic w the b20 vtech franken motor. Recently it overheated and the catch can was full of coolant. Im thinking blown head gasket. I got the manifolds off no problem but there was a lot of oil/wet in the intake side. The valve cover and cams came off like they are supposed to but after i took the 10 head nuts off (they were 12 sided) the head will NOT come off or even loose. I swear the thing is welded on. I believe it should just lift off but it wont even wiggle. Am I missing something? I don't even see any space between head and block where ther should be a gasket. HELP!
Old Apr 8, 2023 | 08:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20 vtec head issues
Use a 3/16" hex key/socket and remove the studs too. Then pull the head off. If it was welded, you would see a weld line all around the bottom edge of the head where it meets the block. It is probably just stuck.
Old Apr 10, 2023 | 03:45 AM
JDAL89's Avatar
That was it. Took a whole can of kroil and a breaker bar to get the studs loose but as soon as they were out it popped right off. Thank you!
Integra_drk
Feb 13, 2012 08:52 AM
thirsk66
22
Jun 4, 2011 09:03 AM
volcom_7_1
Jun 20, 2009 04:08 PM
Coolero
Oct 23, 2007 11:04 PM
aser1z
Nov 1, 2005 07:11 PM
