How much engine movement with Hasport mounts is normal? (Video included)
Old Apr 7, 2023 | 01:50 PM
Ashz_ED8's Avatar
Default How much engine movement with Hasport mounts is normal? (Video included)
Alright so as the title says I’m wondering how much movement is OK or normal with Hasport motor mounts. Specifically 62A street spec. As shown in the video, the engine slightly moves back and forth when revving in 1st gear with the car off the floor. I’m just unaware as to if that’s a normal amount or not. I have a 91 crx with a b18b swap on those mounts and I’m getting this singular clunk / bang when releasing the clutch into 2nd gear. It shakes the middle of the dash which makes me think it’s the rear motor mount. The mounts themselves have only been installed for a year and have only seen 4k miles. I’m able to eliminate the clunking by really focusing on matching the revs to the gear. So I can’t tell if it’s just lack of driver mod or this mount. I’m about to check it for tearing when I get home from work but figure I’d try and get a second opinion as well. Sorry for the short video, it only lets me add a short clip.
File Type: mov
Old Apr 7, 2023 | 03:41 PM
Chance EG's Avatar
Default Re: How much engine movement with Hasport mounts is normal? (Video included)
That looks pretty normal to me, especially considering you're on the 62A bushings. When you installed them, I'm guessing you made sure to get the brackets tight and the bushings torqued to spec?
The clunk you hear is more likely something with the transmission than with the mounts. It's also worth noting that there should be two additional engine torque mounts - Besides the three motor mounts on the trans, rear t bracket, and timing belt side of the engine, there are two additional torque mounts that are sometimes missing on these cars - One that attaches to the transmission, and the other if I remember correctly on the AC compressor bracket.
That being said, I think your problem is something with the trans and not the mounting.
Old Apr 7, 2023 | 03:53 PM
Hasport's Avatar
that amount of movement is normal. check and make sure your rear T bracket isnt touching the subframe
Old Apr 7, 2023 | 07:36 PM
Ashz_ED8's Avatar
Just got home and took a look at it. It’s not touching the subframe but it’s close (see photo). Is that enough clearance ? Also, it looks like the bracket is resting on the bolt of the motor mount as seen in the next photo. Could it be due to the mix matching of a innovative T bracket and Hasport mounts? At the time of purchase, I wasn’t really fully knowledgeable about these swaps so forgive me. Would switching to the proper Hasport hydro t bracket resolve that?
Old Apr 7, 2023 | 07:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Trim the bracket around the bolt head to gain some clearance.
Old Apr 7, 2023 | 07:48 PM
Ashz_ED8's Avatar
Yea everything was torqued to spec. I actually just got done taking apart my trans. All syncros were replaced with carbon syncros, new 1-2 and 3-4 sliders, all new bearings, MFactory lsd and FD. I checked clearances and everything was within spec. Transmission feels super good. No grinds nothing. Only thing is this singular thumping when releasing the clutch into 2nd.
Old Apr 7, 2023 | 07:50 PM
Ashz_ED8's Avatar
Will do
Old Apr 8, 2023 | 07:35 PM
Ashz_ED8's Avatar
Originally Posted by Ashz_ED8
Will do
Just tested everything out today after trimming up the area around the bolt head. Car feels completely different in a good way. Way less cabin vibrations and noise while driving. Can’t believe I never noticed that. It also fixed the clunking issue I was having.
Old Apr 8, 2023 | 09:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
turbodailydan
Aug 16, 2010 05:01 AM
car5car
Feb 28, 2009 08:07 PM
Turbo-charged
Mar 11, 2008 04:24 PM
Mrob91GS
May 8, 2005 08:08 PM
enhancedCL9
Mar 23, 2003 11:56 AM
