Messed up phillips bolt that connects the rotor to the knuckle How should I fi this ?
Old Apr 6, 2023 | 07:36 AM
MassDestruction's Avatar
Default Messed up phillips bolt that connects the rotor to the knuckle How should I fi this ?
As you can see I have destroyed it. Looking for suggestions on how to solve the problem of getting it out. It's REALLY stuck in there
Old Apr 6, 2023 | 07:54 AM
Chance EG's Avatar
Default Re: Messed up phillips bolt that connects the rotor to the knuckle How should I fi th
Very common, I think some people opt to not put screws back in for that reason. If you do, just put some anti-seize on them, and get them loosly hand tight. No need to choke them down.
I'd try using a drill, drill part way into the screw and then try to reverse the drill, see if it catches enough to pull the phillips out. Worst case you may just need to drill the whole head off.
Found this that shows what I'm talking about -
Old Apr 7, 2023 | 10:46 AM
spAdam's Avatar
Loved
Community Favorite
Lesson learned. Next time, use one of these:
Old Apr 7, 2023 | 11:04 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Use a chisel or punch to make an indentation away from the center on the screw, then hold the chisel/punch at an angle and hit it with a hammer; to drive it out in a counter clockwise rotation.
Old Apr 7, 2023 | 07:09 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Also for the impact, you need to get a JIS impact bit, not phillips. It's one reason they always tend to strip is the JIS screw doesn't have the rounded cross in the cross slot like a phillips. Instead it's a straight cross with a bit of a circle in the insides.
Differences can be seen and explained here:
https://chapmanmfg.com/blogs/news/ph...the-difference
Old Apr 8, 2023 | 09:20 AM
spAdam's Avatar
Loved
Community Favorite
We should all have JIS in our toolboxes for working on Japanese stuff. I have a couple for bicycle work and the bits for the impact, but that’s unfortunately it.
Old Apr 10, 2023 | 04:21 AM
I wanted to thank here everyone for there advice. Thank you so much, it's really helped out! I did manage to get it out. What worked for me is using the impact screwdriver. There was just enough meat for using a bigger bit and I hammered away. It eventually came out with A LOT of persuasion lol.
telekineticz
Aug 10, 2009 02:08 PM
sonny0330
May 29, 2008 06:53 AM
crx90rcr
12
Jan 3, 2005 05:21 PM
Dawsonb17a
Jun 28, 2001 09:08 AM
