Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Which 1 of these is most likely the issue? 2008 [2.2 Diesal]
Old Apr 4, 2023 | 08:40 AM
CnPx's Avatar
Default Which 1 of these is most likely the issue? 2008 [2.2 Diesal]
The car sometimes jumps halfway down the road and greatly limits the power. It throws an error about PGM-FI on the centre console. But then other times he will start up and run mostly fine granted a bit heavy sort of sounding. Also the car barely even starts even more. It always takes for ages if you can get it going at all.
Here is what I got when I plugged it in. I know about the air bag error. That's a module I gotta send off. Don't worry about that.
After researching for ages I am getting several different answers.
I changed the fuel filter with the exact same issue but then someone said it has to be a certain filter or it won't solve the issue. But surely if that was the issue it would atleast make a difference rather then be the exact same?
I am being told it's the injectors and then another person said it's a fuel rail censor? At this point I just have no idea.
Old Apr 4, 2023 | 12:25 PM
Ryanthegreat1's Avatar
Default Re: Which 1 of these is most likely the issue? 2008 [2.2 Diesal]
Should be able to see live data for that sensor and figure out if the sesor has an issue or if the fuel pressure is actually low.
Old Apr 5, 2023 | 12:58 PM
CnPx's Avatar
Oh really? My mate doesn't really know to much about that diagnostic kit as he hasn't had it very long and he isn't the best with technology 😂 I will ask him to plug it back in and see if we can work it 😁
BlueIntegraBoy
Jun 8, 2011 06:15 PM
aznoophi
Apr 2, 2008 09:52 AM
Mychal71
Aug 18, 2006 05:40 PM
ConceptS14
Oct 25, 2005 08:14 PM
88turdbucket
Mar 21, 2005 03:48 PM
