engine serial numbers
Old Apr 3, 2023 | 04:49 PM
Stock95delsol's Avatar
Default engine serial numbers
are the starters and solenoids the same on all B16A engines? ...
I'm going to order a starter on ebay and need to know before I buy because the previous owner told me that my 95 del sol has an 89, JDM DOHC 1.6. I was trying to verify this information. the number below "B16A" on my block is 5504696. does this contain a date code? if not how to I determine the date my engine was manufactured?
THANKS....
Old Apr 3, 2023 | 05:28 PM
Maxcapacity's Avatar
Default Re: engine serial numbers
If the block has only "B16A" without a following number, it would be a first gen B16.. You can also look at the front of the cylinder head - starting just above top left exh mani stud, the first left circle stamp you will notice that it has either e.g. (8/9) or (9/0) or (9/1) which year it is..
Stock95delsol
May 6, 2022 09:00 PM
E-mac
Jul 13, 2012 04:09 PM
saunders400
May 26, 2011 10:20 AM
dime@fsmail.net
Feb 8, 2008 12:53 PM
Civic168
Nov 28, 2005 10:21 AM
