NEW THREAD: bogging down/conking out while coasting
Old Mar 31, 2023 | 02:31 PM
Justin02Accord's Avatar
Default NEW THREAD: bogging down/conking out while coasting
Hi all,
'02 Accord EX.
I recently had a bad misfire (I started a thread for it but the problem has somewhat changed). I replaced the spark plugs and wires, and that made it 90% better. Distributor and rotor had been replaced less than a year ago and are good. Then I removed and cleaned the intake manifold and EGR valve and passageway.
I have had a CEL 0325 for awhile. I replaced the knock sensor, but with a cheapie ebay sensor, and afer resetting the code, it came back pretty quickly. I'm going to get an OEM sensor from a junkyard if possible & will buy one if not.
I also have a 1457 code, which I'm hoping is just my gas cap. Someone stole my cap and I had an old rusty one laying around so put it on, and this code came up within a day. So I feel pretty confident that's the problem. Will replace with a good cap this weekend.
Now, the problem: after cleaning the intake manifold and throttle body (which were unbelievably caked in goo), the car ran as good as new for a few days. Today I drove it to Durham (25 miles away), and there was a slight misfire while at low revs a couple of times; but as soon as I began accelerting, it was fine.
On my way home, however, the car conked out multiple times when I was coasting. It held idle just fine, if I could get to idle. But several times as I was gliding to a stop, the engine conked out and the dash lights all lit up. It started right back up every time, and I made it home okay, but the problem got worse as I went along. For the last mile, it *really* struggled to stay alive.
I know Nissans have something called a Boost Controlled Deceleration Device, which ensures the engine keeps getting air/fuel flow when your foot is off the accelerator. Do our cars have something similar?
Any ideas where I should start?
Thanks!
Old May 10, 2023 | 06:51 PM
Default Re: NEW THREAD: bogging down/conking out while coasting
Solution found, just in case anyone is interested.
I changed the oil.
That's it.
After researching this issue for days, I found more than a few posts/threads outside and inside this forum where a Honda mechanic recommended an oil change to fix this specific kind of misfire/bogging under acceleration. Why? How? I don't know. But it worked. I've put 300 miles on it under every condition since then, and it's been perfect.
So there you go.
Old May 11, 2023 | 05:55 AM
nicolaselias's Avatar
Loved
Community Favorite
Interesting. How long was the previous oil in there for?
Old May 12, 2023 | 08:57 AM
Old oil was in for less than 2,000 miles, BUT it was almost a full year, since I didn't drive the car from November when the original misfire started, until just a few weeks ago.
Austin Hamlin
Jan 24, 2024 08:50 PM
E.C.Smith76
Dec 7, 2013 07:51 AM
Eighty-Nyne
Nov 10, 2008 06:03 PM
kennylxix
Jan 10, 2006 12:19 PM
Rod.
Jan 2, 2005 11:33 AM
