Hondata s300 Not showing sensor data.
Old Mar 30, 2023 | 05:21 PM
heilmansamuel's Avatar
Default Hondata s300 Not showing sensor data.
I’ve already check all the forums with the same issue but I still have the same issue. I’ve double checked everything on the ecu and everything else works, I can upload, I can download. I just can’t read the sensors on the computer. On board data logging is turned off, j12 is desolder, capacitors soldered to c52 and c51, j1 is jumped and r54 has 1.1k. Ecu is a P28. ECU looked to be chipped before and had some components replaced. I bought the ecu online. I pretty much believe it has to be a socketing issues. Anything helps, thank you.
Pictures of the ecu
Sockets
J12
Back of socket
Back of j12
stevenDAtegra
Engine Management and Tuning
12
Dec 18, 2009 09:37 AM
sackdz
Sep 29, 2009 06:14 AM
asc
Aug 14, 2008 08:39 PM
