CTR Crank pulley, is it worth it?
Old Nov 18, 2002 | 09:23 AM
9KRacer's Avatar
New User
Default CTR Crank pulley, is it worth it?
I am in the process of having a motor built. At this point I could add the CTR crank pulley. I have heard good and bad things about it. I am testing the waters to get a general thought. All inputs welcome.
Old Nov 18, 2002 | 09:25 AM
Stupid Ass's Avatar
Default Re: CTR Crank pulley, is it worth it? (9KRacer)
From what I hear Chris you can just lighten the stock pulley.
Old Nov 18, 2002 | 09:27 AM
vtecvoodoo's Avatar
Future Texas Boy
Not worth it IMO.
Old Nov 18, 2002 | 10:04 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: CTR Crank pulley, is it worth it? (C5_ALLMOTOR)
If I bought one, even if it was new, i`d check to make sure it`s balanced.
[Modified by vtecvoodoo, 11:04 AM 11/18/2002]
Old Nov 18, 2002 | 10:12 AM
EKhatch's Avatar
I take it that the motor you are having built isn't being blanced? Or you haven't got to the assembly yet? If the bottom end is already put together I would recomend using the original pully.
Just my $.02
Old Nov 18, 2002 | 10:19 AM
9KRacer's Avatar
New User
Default Re: CTR Crank pulley, is it worth it? (EKhatch)
For the quick responses..
Old Nov 18, 2002 | 10:27 AM
ejprimo's Avatar
ryan,
how do you check to see if the pulley is balanced? i bought one of those wanna-be N1 pulleys from inlinefour b/c i wasnt using my a/c or p/s anymore.
Old Nov 18, 2002 | 10:38 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: CTR Crank pulley, is it worth it? (ejprimo)
Take it to a good machine shop.
Old Nov 18, 2002 | 10:50 AM
JD_B18CDX's Avatar
All honda crank pulleys are unique to the engine block design.
Aside from being a pulley to drive belts, it also acts as a harmonic balancer.
It prevents vibrations that will accelerate the wear on the main berings.
On honda engine, Each pulley is balanced towards a particular frequency range based on engine operating speed(rpm), crankshaft design (stroke) and crank weight. Unfortunately, its is a one piece design.
Some chevy motor's harmonic balancer are sperate from the pulleys. All they have to do is change the crank pulley (retain the same balancer) to a smaller one and all the drive accesories run slower and producer less drag.
Putting a pulley that was not designed for the block might (most likely) result in a shorter life for the crank main bearings.
To answer your question, use the pulley that came with your motor.
Unless you made drastic changes in you crank or engine design use the stock ones.
[Modified by JD_B18CDX, 2:55 PM 11/18/2002]
Old Nov 18, 2002 | 12:30 PM
9KRacer's Avatar
New User
Default Re: CTR Crank pulley, is it worth it? (JD_B18CDX)
Alright, thanks guys...
preludedriva
Aug 15, 2007 06:42 AM
IGotNoSwap
21
Sep 27, 2005 08:17 PM
Quick99
Sep 13, 2005 05:06 PM
stivic
May 7, 2005 08:56 PM
gtowni3
Oct 15, 2004 08:29 PM
