2000 honda civic ex 5 speed manual d16y8 idle problems
Old Mar 20, 2023 | 06:15 PM
00hondacivic5sp's Avatar
Default 2000 honda civic ex 5 speed manual d16y8 idle problems
so I've been having idle problems with my civic, I start it up and it idles at 3k for a lil then drops to 1.5k and surges from 1.5k to 2.5k rpms, I replaced the iacv, cleaned fhe throttle body, replaced fhe map sensor, bled the coolant, flushed coolant and put in oem blue honda coolant, no cel when all connectors plugged in, i put my finger over the hole for the iacv in the throttle body while it was running and the idle drops and smooths out to about 1.3k rpms, so I unplug the iacv and it stays at 1.3k and then I mess with the idle screw and if you bottom it out the idle will go to down to about 1.1k but idles kinda funny still, I checked for vacuum leaks and there are none, im at a loss..
Old Mar 24, 2023 | 04:31 PM
RA012626's Avatar
Default Re: 2000 honda civic ex 5 speed manual d16y8 idle problems
My h2b had the same problem and I tried everything like you did. Ended up just putting an iacv block off plate since my only component running off the engines power is my alternator so I figured I didn’t really need it. Fixed the problem. If you still have a/c, power steering, etc. you most likely need a new iacv. You can tell if its an iacv problem if it stops surging after you key off and on really quick to reset the cars electronics.
JFKcivicex
Nov 2, 2019 02:29 PM
jpearce91
Sep 18, 2018 06:20 PM
agb22
Honda Civic (2006 - 2015)
Nov 29, 2016 11:24 PM
methyd
May 13, 2004 02:36 PM
delSolLS
Feb 18, 2002 04:59 AM
