electrical problem
hello everyone, i own an ek3 (1997 d15z6) and yesterday i was doing some wiring work for me new pair of headlights. after i was done my car wont start, i hear the fuel pump working, it cranks ok, my battery has voltage, i checked every fuse and i still havent got any solution. my batttery warning light wont light with the key in on position like it used to do prior to the problem. if anyone knows anything or had the same problem any help would be apreciated
if you did not remove the negative battery terminal prior to working, you likely blew a few fuse or two. Check that. It's either in the underhood or driver dash fuse box.
