Jdm B18c into ek
If using oem gsr Intake manifold you have to use the gsr cable and bracket. But if using aftermarket Intake manifold you should be able to use b16, b18b or itr cable and bracket. You may be able to rig up your single cam cable.
I just bought a throttle cable from O’Reilly but now the issue is the part that connects to the firewall doesn’t fit.Would I need to file down a bit of the firewall ?
So I got the car running and moving but now I’m having a click no start issue but I turn the key over to start a couple times and then the starter turns on. I checked all my grounds making sure they were snugg and I came across one that was eroded. Can that me my cause to a click no crank?
Right now I have an OEM EG Si cable, and just from looking I can tell that the included bracket from S2 isn't going to line up right. It's Skunk so of course there's 0 information they provide on it.
@JRCivic1 Would you happen to know off hand what cable/bracket I should use with a Skunk2 Ultra street manifold in an EG?
BoostedSixthGen
28
Apr 23, 2003 09:05 AM
