B series obd1 harness and ex civic harness obd2
Old Feb 28, 2023 | 03:29 PM
R3lkstar's Avatar
Default B series obd1 harness and ex civic harness obd2
So I have this b series harness that came from my my b18c and it came cut up so I went to look for another wiring harness came across this 2000 civic ex harness complete but w some plugs broken. I was just wondering if im able to replace those plugs w the b series plugs. I also have a 1999 non vtec dx wiring harness and wondering if I can use that as replacement parts aswell.
Old Feb 28, 2023 | 05:37 PM
Johnnel's Avatar
Default Re: B series obd1 harness and ex civic harness obd2
What car are you putting the swap in that will decide what harness you can use.
Old Feb 28, 2023 | 06:02 PM
R3lkstar's Avatar
I’m gonna be swapping it into an ek civic coupe
Old Feb 28, 2023 | 08:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Use the engine harness that CAME with the chassis that you intend to swap the engine into... and if it is missing, one JUST LIKE IT. If you have a '99 Civic EX auto chassis, use a '99 Civic EX auto engine harness. Then, add/subtract or change/lengthen any plugs that need to be altered. Use all of the plugs from the OBD-1 engine harness that you can.
Old Feb 28, 2023 | 10:40 PM
R3lkstar's Avatar
I’ll end up using the ex harness bc it already has vtec plugs on em and the harness that came w my car is non vtec so it’ll just be easier to use the ex harness and fix the plugs using the obd1 b series harness as a replacement parts.
Old Feb 28, 2023 | 10:43 PM
R3lkstar's Avatar
So just to be clear its fine to use the b series obd1 plugs and re wire it to the obd2 ex harness
correct?
Old Mar 1, 2023 | 04:02 AM
Johnnel's Avatar
Correct
Old Mar 1, 2023 | 07:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
correct?
Absolutely.
R3lkstar
Engine Management and Tuning
Feb 28, 2023 01:21 PM
Cornfed simp
Sep 18, 2022 05:16 AM
CivicSi95
May 9, 2013 10:48 AM
shocker911
May 14, 2010 02:29 PM
Stroker
Dec 10, 2003 06:32 AM
