Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2014 honda civic si left turn signal not working
Old Feb 19, 2023 | 01:55 PM
Tntcustoms101's Avatar
Default 2014 honda civic si left turn signal not working
All other lights work properly. Indicator says the lights blinking but nothing. Marker light works but no turn signal on left front only. Even with hazard button engaged the only one not workin is left front turn signal. Ive read it could be the fuses(checked and good) relay( no idea where it is and no form ive seen showing location) and also i heard it could be the switch itself. Any help would be appreciated. Also wiring looks good. Thank u
Old Feb 19, 2023 | 04:01 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2014 honda civic si left turn signal not working
Did you check the bulb? It may be the bulb. The bulb is dual filament; one filament for the turn signal and the other filament for the parking light.
Old Feb 20, 2023 | 09:21 AM
yes the bulb is fine. Even changed it 3 times to make sure.
hybridnorth
37
Feb 16, 2019 06:13 AM
-Justin-
Feb 17, 2017 10:47 AM
baseballbirch
Honda CR-V & Element
Aug 24, 2015 09:08 AM
obd1_crx
Sep 19, 2008 11:32 AM
