Interchangable honda parts for Del Sol
Hi All,
New to the del sol scene! doing a complete rebuild and will be starting the suspension here in the next month.
Had a few questions regarding the interchangeable suspension parts if anyone knows or has a list it would be greatly appreciated!
Mine is a 96 Del Sol Si
Mevotech has the complete front kit, any opinions on their stuff? Good, bad, OK?
No kits for the back and would need to compile the components myself. would be great to know what is exchangeable between the del sol, civic, integra
Thank you!
Thank you!
Welcome to the "del Sol scene"!
Sorry, can't help you with your questions but I suggest you try the Reddit del Sol board. It may be more active (with del Sol owners) than this one.
edge://newtab (reddit.com)
Good luck!
Good luck!
Good luck!
Good luck!
Where is the vomit emoji?
As Sic_DA_Nine mentioned, suspension parts from a 92-95 Civic or 94-01 Integra will also work. The exception would be ITR rear suspension, which is unique due to the control arms. Any other Civic/Integra parts will work.
ej6kid
Oct 26, 2010 03:42 PM
