Hondata S300 errorcode 16
need help with error code 16.
The car is a civic 2000 with obd2b harness which is connected via jumper to the control unit. ECU = P30 G00.
The injectors are RC550 SL9, with ignition switched each injector has 12.9x volts.
The dead times are set by default:
@ 0,00V = 0,80ms
@ 8,09V = 0,80ms
@ 10,11V = 0,62ms
@ 12,13V = 0,40ms
@ 14,16V = 0,29ms
@ 16,08V = 0,23ms
@ 24,55V = 0,23ms
Fuel pump: Fuelab 340l/h @3bar
Fuel filter: Nuke Performance 100Micron
Pressure regulator: Fuelab with Gauge
After starting the engine immediately comes the error message 16 "Injectors".
If you turn off the car, the error is extinguished, but comes back immediately when you start the car again.
Is this a problem or is it normal with the P30 G00 and only the hook must be set that the error should not be observed?
@ 0,00V = 0,80ms
@ 8,09V = 0,80ms
@ 10,11V = 0,62ms
@ 12,13V = 0,40ms
@ 14,16V = 0,29ms
@ 16,08V = 0,23ms
@ 24,55V = 0,23ms
@ 0,00V = 0,80ms
@ 8,09V = 0,80ms
@ 10,11V = 0,62ms
@ 12,13V = 0,40ms
@ 14,16V = 0,29ms
@ 16,08V = 0,23ms
@ 24,55V = 0,23ms
@ 0,00V = 0,80ms
@ 8,09V = 0,80ms
@ 10,11V = 0,62ms
@ 12,13V = 0,40ms
@ 14,16V = 0,29ms
@ 16,08V = 0,23ms
@ 24,55V = 0,23ms
project-boosteD
Engine Management and Tuning
May 23, 2010 03:07 PM
nineohnine
Jun 16, 2009 07:28 PM
legendboy
Apr 22, 2002 01:35 PM
